15 years agoSOPC problem using Avalon-MM tristate bridge and memory
I'd like have some memory in my design that is on-chip (dual port) but outside the SOPC so that I can connect to the second port. This looks possible when I add an Avalon-MM tristate bridge and an ID...
15 years agoi think i had your situation backwards, i thought you wanted to connect a RAM in SOPC Builder to the outside world
to connect SOPC Builder to RAM on the outside, your approach of using the MM Slave template is correct
