15 years agoSOPC problem using Avalon-MM tristate bridge and memory
I'd like have some memory in my design that is on-chip (dual port) but outside the SOPC so that I can connect to the second port. This looks possible when I add an Avalon-MM tristate bridge and an ID...
15 years agoI'm confused by the suggestion to use the MM master template as my current approach is to design an HDL component with an Avalon MM slave port and a bunch of external ports. It's looking a bit ugly as there are a lot of external ports.
The logic outside SOPC is big and nearly all done in schematic, so I don't fancy writing an HDL wrapper for it.
