18 years ago
sopc Generation Error
Hi I am trying to generate the SOPC example design provided with Nios II EDS. (Standard.qpf) and I am getting the following error. Any one know how to fix this? Is it anything to do with setting the path?
Info: Starting PTF file elaboration.
3 [main] sh 1428 fork: child 3920 - died waiting for longjmp before initialization, errno 11
c:/altera/72/quartus/sopc_builder/bin/nios_sh: fork: Resource temporarily unavailable
Error: C:\altera\72\nios2eds\examples\verilog\niosII_cycloneII_2c35\low_cost/NiosII_cycloneII_2c35_low_cost_sopc.ptf: Failed to refresh PTF file
    Hi ganenn!
    I get the same error while trying to generate the DE_NET example system. Have you found a way to get your system working?
    Thanks for any clues, Macbeth
    Change the permission on directory. I think when you copy those folders they stay with the read only permission.
    Thanks for your answer, the directory really was in read-only. However, the real problem was my Windows Vista which by default is not compatible with the cygwin1.dll of the SOPC system. So I had to replace the cygwin1.dll in altera\72\quartus\bin\cygwin\bin with a new one from a recent cygwin-installation. Now the generation works just fine.
    Hi all,
    Any of you guys tried using the NIOS II IDE with windows vista? I am getting the following error.
    Post-processing to create ext_flash.flash
    /cygdrive/c/altera/72/nios2eds/bin/elf2flash: line 2: /cygdrive/c/altera/72/nios2eds/bin/sh_jar.sh
    Hi all,
    I meet the same problem.I've rebuilded the project,tried other's project,even reinpaired the QUartus7.2.But the error still exits.
    please help me,thank you!
    [email protected]
