15 years ago --- Quote Start --- I get a very similar error.... cpu_0/instruction_master: Base Addresss for pll conflicts with slow_peripheral_bridge/s1 cpo_0/data_master: Base Address for pll conflicts with slow_peripheral_bridge/s1 This error occurs after the... This occurs because memory is a slow peripheral as compared to the nios2 clock.So if you want to remove any clocking problems u have 2 options 1. Either use a clock crossing bridge as suggested in one post to remove the clock crossing issues 2. use the ddr clock for all the other peripherals. I used the ddr clock.There is an example design avialable for it.You can read about it in the ddr memory documentation for external memory interface.
