16 years ago
SOPC does'nt generate .BSF file
Hi there, im new to SOPC and everything! Im working on this article:
http://www.nioswiki.com/embedded_systems_lab
http://www.nioswiki.com/@api/deki/files/218/=embedded_systems_lab_v80_rev3.zip
Everything goes fine untill it gets to inserting DE1_system (generated by SOPC) to a schematic Block diagram, it needs a .BSF file, as described in SOPC manual, it must generate a .BSF file so i can add it to schema, but it doesnt! The .sopc file is attached, i checked few options that SOPC Builder has, didn't help. Even i tried to create .bsf file myself, but verilog source file is complicated somehow, in fact its just a comment!! No port definition or etc!! DE1_system.zip contains SOPC file, the other file is the whole project, you can find "DE1_system.v" which is nothing but a comment!
    What I suspect is really happening is that the SoPC system is not actually generating. Look closely at the output of SoPC builder. Were there any errors?
    Jake
    Problem solved. Thank you to note that, since the message was "Generation Successfull" i didnt note an error, the name of a module was incorrect (started with "_"), thank you so much.
