14 years agosopc-create-header-files generates wrong header file
Hi all!
I installed Quartus II Web Edition v11.0 for Linux to be able to work on Linux with MMU on Neek project. I followed instructions on this page: Extreme_Guide_to_Kill_NEEK_with_u-boot As part of normal procedure a header file describing the hardware should be generated by sopc-create-header-files script: sopc-create-header-files --single Custom fpga.h Fortunately, the mentioned link has already generated Custom fpga.h file so it is possible to compare two header files. Unpleasant surprise is that sopc-create-header-files generates header file incorrectly. It wrongfully clears values for FAST_TLB_MISS_EXCEPTION_ADDR, EXCEPTION_ADDR, RESET_ADDR and BREAK_ADDR. All those variables have distinctive values different from zero in .sopcinfo file. After fixing those values manually kernel boots normally. This smells like sopc-create-header-files bug or I do not understand something? Thanks, Vladik
