18 years ago
SOPC Components not found in Quartus 7.2
I recently upgraded to Quartus 7.1 and went through the pain of migrating all my SOPC components to the new tcl format. The components were all in a library pointed to by the global libraries path.
I open the project in 7.2 and SOPC cannot find these components any more!
My paths are something like this ..
c:\branch7.2\mylib\--component1\hdl
                  \--component2\hdl
                  \--etc.
With v7.1 I placed an empty file .recurs in the c:\branch7.2\mylib directory which appeared to allow SOPC to recurs the subdirs properly. Therefore only needing one path for all my library components. But in 7.2 the SOPC tools does not find them any more.
I've tried adding the paths for c:\branch7.2\mylib as well as c:\branch7.2\mylib\component1 etc. in both project and global libraries paths as well as in SOPC "tools->options->ip search path" with no joy.
Can anybody help me?
    :) My parameters are only integer and moving them from generics to constants within my code and disabling the 'add_parameter' lines in _hw.tcl fixes this problem.
    This is not great as I can no longer parameterise my component! :mad:
    Thanks again Klaus for your help.
    The parameters should have default values :
    ENTITY component IS
      GENERIC
      parameter  : integer := 4
    Try to regenerate your component with the component editor. Create a new SOPC system an insert your component. Maybe it helps.
    My component parameters already have default values assigned I'm afraid. For example :
    entity StreamCapture is
    generic (
    	master_address_width	: integer := 32;
    	master_data_width		: integer := 64;
    	stream_data_width		: integer := 32;
    	stream_length_width		: integer := 24
    port (
    ...etc.
    If I edit the component again I get what seems to be incorrect tcl for the simulation files property with a dangling " :-
    set_module_property "simulationFiles" "
      "StreamCapture.vhd"
    which accounts for the error on loading the SOPC system :
    Error: StreamCapture_0: extra characters after close-quote
    where originally this was :
    set_module_property simulationFiles {
      "PP_StreamCapture.vhd"}
    reverting this removes the Error: StreamCapture_0: extra characters after close-quote
    Unfortunately I haven't found a combination that allows me to have generics as parameters. I tried removing the _ and capitalising the names with no success.
    The correct syntax for set_module_property simulationfiles according to the manual should be :
