18 years agoMy component parameters already have default values assigned I'm afraid. For example :
entity StreamCapture is
generic (
master_address_width : integer := 32;
master_data_width : integer := 64;
stream_data_width : integer := 32;
stream_length_width : integer := 24
port (
...etc. If I edit the component again I get what seems to be incorrect tcl for the simulation files property with a dangling " :- set_module_property "simulationFiles" "
"StreamCapture.vhd" which accounts for the error on loading the SOPC system : Error: StreamCapture_0: extra characters after close-quote where originally this was : set_module_property simulationFiles {
"PP_StreamCapture.vhd"} reverting this removes the Error: StreamCapture_0: extra characters after close-quote Unfortunately I haven't found a combination that allows me to have generics as parameters. I tried removing the _ and capitalising the names with no success.
