Altera_ForumHonored Contributor17 years agoSOPC Builder "Validation Error" I'm new to altera software and am attempting to use SOPC Builder to build a Nios II system. I'm using Quartus II v8.0 service pack 1. But when I click generate after adding the components in SOPC bui...Show More
Altera_ForumHonored Contributor17 years agoyou must edit "memory on chip" (if you use it) in the cpu , then you can normal generation
Recent DiscussionsFree Licence for Max+PlusIIMAX10 ADC - getting it to simulate in ModelsimFailed to run ip-setup-simulation:Compile option not saved (reversed to default)How to fix Error(23782): Failed to find an expected report
