16 years agoSOPC builder connection issues
Hi All,
I am using SOPC builder to use NIOS II processor and 2 on chip dual port memories. I have connected one port of each memory to instruction and data master of NIOS processor. Now I want to connect the other 2 ports of memory(Avalon MM slave interface) to some outside user defined interface. But I am not able to generate the system from SOPC builder till all ports are connected. Is there any alternative way in which i can generate the system without connecting the ports? Attached is the snapshot of SOPC builder project. Thanks in advance.
