The ultimate goal is to have a script(makefile) that download my project from a versioning sytem (svn) and then builds the complete project including all code generation.
My findings for Q10.1:
There is some progress: when issuing the command :
sopc_builder --generate --nosplash It will build your system both in windows(cygwin) and linux (ubuntu). However... apparently there are still components that need a display to connect to. This means you can still not generate everything on a headless system. The pcie generator throws a 'headless exeption' because it relies on some java awt libraries. I hope this will get cleaned up in one of the next versions.
In the mean time you could start a (virtual) x server:
export display=:1
xvfb :1& Does anyone have a better solution?
