15 years agoSOPC Builder - sopc_builder.dispatch_event: Error! - java.lang.NullPointerException
I use Ubuntu 64bit and the 10.1sp1 toolchain(full license).
The sopc builder doenst generate the design. It just tells me(once) that the system generation was successfull. I think the problem starts at the ptf file elaboration due to java problems. Could somebody help me? PS: Got warnings: Custom Instructuion components can be edited through the Component Editor. uniphy_ddr2_dim: An average delay difference between address and command.... uniphy_ddr2_dim: 'Qucik simulation models are NOT timing accurate. Some simulation memory models may issue warnings or errors PPS: sopc tells me via Info, that it founds his stuff at [altera_dir]/10.1/quartus//[some more]. Why do I get // instead of /? --- Quote Start --- Info: Starting PTF file elaboration [some arguments] (:3697): Gtk-WARNING **: /usr/lib/gtk-2.0/2.10.0/immodules/im-ibus.so: wrong ELF class: ELFCLASS64 (:3697): Gtk-WARNING **: Loading IM context type 'ibus' failed (:3697): Gtk-WARNING **: /usr/lib/gtk-2.0/2.10.0/immodules/im-ibus.so: wrong ELF class: ELFCLASS64 (:3697): Gtk-WARNING **: Loading IM context type 'ibus' failed (:3697): Gtk-WARNING **: /usr/lib/gtk-2.0/2.10.0/immodules/im-ibus.so: wrong ELF class: ELFCLASS64 (:3697): Gtk-WARNING **: Loading IM context type 'ibus' failed (:3697): Gtk-WARNING **: /usr/lib/gtk-2.0/2.10.0/immodules/im-ibus.so: wrong ELF class: ELFCLASS64 (:3697): Gtk-WARNING **: Loading IM context type 'ibus' failed sopc_event_queue.dispatch_events: ERROR java.lang.NullPointerException at sopc_ptf.sopc_port.is_clock_pipelined(sopc_port.java:163) [some more at something stuff - cut it] Info: Finished elaborating PTF file. Executing: /opt/altera/10.1/quartus//sopc_builder/bin/sopc_builder --classic --generate /home/walther/git/canrouter/usr/sopc/router_ports/rps.ptf Info: Starting generation...[some arguments] (:3741): Gtk-WARNING **: /usr/lib/gtk-2.0/2.10.0/immodules/im-ibus.so: wrong ELF class: ELFCLASS64 (:3741): Gtk-WARNING **: Loading IM context type 'ibus' failed (:3741): Gtk-WARNING **: /usr/lib/gtk-2.0/2.10.0/immodules/im-ibus.so: wrong ELF class: ELFCLASS64 (:3741): Gtk-WARNING **: Loading IM context type 'ibus' failed (:3741): Gtk-WARNING **: /usr/lib/gtk-2.0/2.10.0/immodules/im-ibus.so: wrong ELF class: ELFCLASS64 (:3741): Gtk-WARNING **: Loading IM context type 'ibus' failed (:3741): Gtk-WARNING **: /usr/lib/gtk-2.0/2.10.0/immodules/im-ibus.so: wrong ELF class: ELFCLASS64 (:3741): Gtk-WARNING **: Loading IM context type 'ibus' failed sopc_event_queue.dispatch_events: ERROR java.lang.NullPointerException at sopc_ptf.sopc_port.is_clock_pipelined(sopc_port.java:163) at altera_avalon_adapter_slave_y.SlaveYAdapter.insert_adapters_between_interfaces(SlaveYAdapter.java:34) at sopc_ptf.sopc_default_adapter.insert_adapters(sopc_default_adapter.java:48) [some more at] Info: System generation was successful. --- Quote End ---3 Replies
I solved the problem.
I dont really know exactly what the problem was. But I think somehow I did something bad when I played a bit around with my system. How did I solve it: Dumped the old SOPC Builder design and started a new project. - Altera_Forum
Just hit this same problem. I tried the "go make the SOPC from scratch" thing. I am still hitting the problem. This is with Q12.1SP1.
Any thoughts / guidance on what to do to try and diagnose or work around? Thx, Dave - Altera_Forum
In my case this was caused (but not justified by) me having updated the clock names that various clocks in my SOPC were known as. Now this seems like a perfectly reasonable thing to do and yet if I generate the version with the system assigned names it generates just fine but if I rename certain clocks to be something friendly the generation fails.
Whatever. YMMV. Dave
