15 years ago
SOPC base address error
Dear expert.
I use SOPC to bulid a triple_speed_ethernet_design(Q9.1_example_design) + VGA.
I add VGA IP in sopc and VGA's master connected to ddr2_bot's slave.
Then there are errors about "Error : ddr2_bot.s1: Appears at more than one address(0x00000000,0x10000000)
Why this happen?
    What is the other thing connected to ddr2_bot.s1? The one at the bottom?
    Dear Daixiwen.
    The other thing connected to ddr2_bot.s1.
    (Pipeline Bridge)pb_dma_to_ddr2's m1 connected ddr2_bot.s1.
    Thank you.
    You need to fix the addresses of ccb_dma_to_ddr2 and pb_dma_to_ddr2 to 0x00000000. Currently the ccb_dma_to_ddr2 bridge offsets the addresses by 0x100000000 which means that the ddr2 would be seen at two different addresses depending on the master that would access it.
    I don't think that you need the pb_dma_to_ddr2 bridge.
    Why is your ddr2 clock set to clkin_50 instead of ddr2_lo_latency_128m_sysclk?
