17 years agosof file format?
Stratix III Active Serial question: I would like to know how may bits in my EPCS device I'm actually using given a sof file. How do I do this? If I enable bit stream compression I assume that the number will reduce (seems obvious). Is there a sof file format document anywhere? I have searched, and can't seem to find anything useful. I program via the NIOS i.e. using the EPCS controller via JTAG i.e. I don't use a pof file via the EPCS programming header I have on my board. Thanks, Dave.
