--- Quote Start ---
Critical Warning: No exact pin location assignment(s) for 222 pins of 222 total pins
When run Fitter
--- Quote End ---
If you have the original Quartus project like you said, you should have pin already assigned.
I can't understand why you are missing them. :confused:
Anyway, if you can't retrieve the project settings and contraints, you'll have to reassign them from scratch.
Take your board schematics, open the pin assignment editor in Quartus and put the right pin number beside the signals.
This is a mandatory step.
After this you may also need to set some specific options and some timing constraints, but this depends on your project.
