10 years agosof and pof
Dear Sir,
I have one question for the programming file generation. After finishing the Assembler, I am supposed to have a .sof file in the working folder. Why do I have not? Will Quation II generate sof and pof at the same time? Supposed, according to the experience I have several years ago. I am currently using a QII v9.1sp2 with Web edition license. The attached file shows that the compilation is finished. Although it has some timing violations for the Recovery, it doesn't matter, I think. Thanks. Peter Chang2 Replies
Check the device assignments. Probably you selected a wrong configuration mode.
Does Quartus generates a .pof file? is this missing as well? - Altera_Forum
You can't target a Stratix IV device with the web edition. I didn't know that the web edition would even allow you to compile an unsupported device. Apparently it does but won't generate any programming files. You'll see the same thing if you have unlicensed IP in a design. I'm sure Quartus generated a message telling you why it didn't generate the .sof file.
