8 years agoSOF & STP files -> how to know that STP is a part of SOF ?
Hi All, I have two files - SOF (programming file) and STP (SignalTap files). How can I verify that this STP file is a part of the SOF file (in another words that STP file was included into...
8 years ago.stp files are not "part" of the .sof. The .sof includes the bitstream for including a Signal Tap instance when you program the FPGA. The .stp file is used to configure (before compilation) and control (after compilation and device programming) that instance.
So program your device with the .sof using the programmer or the JTAG configuration section of the .stp file. If the Signal Tap instance defined in the .stp is present in the programmed device, you'll see in the status at the top of the .stp file that you are ready for capture.
