13 years ago
So simple it's stupid: RS232 Receive Module works in Modelsim, fails in DE2-115
Hi. So, I am using Quartus II 12.1 sp1 and a DE2-115 board. I am running the clk at 100 MHz; at the top level it goes through a PLL to generate the 100 MHz clk. At the top level I am putting the data and rx_state on LEDs as well as the 7-seg display. I know the 7-seg display works 100%. Whenever I send a 1 via hyperterminal I get "0000_0001" displayed on the LEDs, which is wrong.
So, I have 2 questions.
1. Do you see a flaw in my state machine / code?
2. How do I verify that my circuit is passing timing? I am used to putting timing constraints on the main clock in Xilinx UCFs. Is it that simple in Quartus? I've looked into using TQ and it seems a bit over kill for a simple timing constraint.
-Joe
    module rs232
        input                                        clk,
        input                                        reset,
        input                                        rxd,
        output                                    txd,
        output                            debug,
        output                                data_out,
        output                                    nd_out,
        //output                            fr_q,
        //input                                    fr_rdclk,
        //output                                    fr_empty,
        //input                                    fr_rdreq,
        input                                ft_data,
        input                                        ft_wrclk,
        output                                    ft_full,
        input                                        ft_wrreq
    // These Values assume a 100 MHz clock with a period of 10 ns.
    // Assume 115200 baud.  Each bit is 1/115200 or 8.7uS.  8.7 us / 10 ns =
    //parameter v_fullhalfbit = 651, v_fullbit = 434;        //50 MHz
    parameter v_fullhalfbit = 13'd1302, v_fullbit = 13'd868;        //100 MHz
    fifo_16x64 fifo_txd_inst
        .aclr(reset),
        .data(ft_data),
        .rdclk(ft_rdclk),
        .rdreq(ft_rdreq),
        .wrclk(ft_wrclk),
        .wrreq(ft_wrreq),
        .rdempty(ft_empty),
        .wrfull(ft_full),
        .q(ft_q)
    metafilter metafilter_inst
        .clk(clk),
        .reset(reset),
        .sigin(rxd),
        .sigout(rxd_m),
        .rise(rxd_rise),
        .fall(rxd_fall)
    // Begin Transmit FSM
        always @ (posedge clk or negedge reset)
            begin
                if (!reset)
                    begin
                        //q1 <= 0;
                        //q2 <= 0;
                    end
                else
                    begin
                    end
            end
    // End Transmit FSM
    // Begin Receive FSM
    //wire                            data_out_i
    //wire                            rxd_m, rxd_rise, rxd_fall;
    reg                        rx_data, data_out_i;
    //reg                            nd_out_i;
    reg                        rx_state, rx_ns;
    reg                    rx_c_fullhalfbit, rx_c_fullbit;
    reg                        rx_c_eight;
    parameter    rx_idle = 4'd0, rx_start = 4'd1, rx_rec = 4'd2, rx_stop = 4'd3;
    assign txd = 1;
    assign data_out = data_out_i;
    //assign data_out_i = (rx_state == rx_stop & rx_c_fullbit == 0) ? rx_data : data_out_i;
    assign nd_out = (rx_state == rx_stop & rx_c_fullbit == 0);
    assign debug = {rx_c_fullhalfbit, rx_c_eight};
    // Begin Next State Logic
    begin
        if (!reset)
            begin
                rx_state <= rx_idle;
                //rx_ns    <=  rx_idle;
            end
        else
            rx_state <= rx_ns;
    end
    always @*
    begin
            case (rx_state)
                    rx_idle:
                        if (rxd_fall)
                            rx_ns = rx_start;
                        else
                            rx_ns = rx_idle;
                    rx_start:
                        if (rx_c_fullhalfbit == 1'd0)
                            rx_ns = rx_rec;
                        else
                            rx_ns = rx_start;
                    rx_rec:
                        if    (rx_c_eight == 4'd7 && rx_c_fullbit == 0)
                            rx_ns = rx_stop;
                        else
                            rx_ns = rx_rec;
                    rx_stop:
                        if (rx_c_fullbit == 0)
                            rx_ns = rx_idle;
                        else
                            rx_ns = rx_stop;
                    default:
                        rx_ns = rx_idle;
            endcase
        end
    // End Next State Logic
    // Begin Output Logic
    begin
        if (!reset)
            begin
                rx_c_fullhalfbit <= v_fullhalfbit;
                rx_c_fullbit <= 0;
                rx_c_eight <=4'd0;
                rx_data <= 8'd0;
                data_out_i <= 1'b0;
            end
        else
            begin
                case (rx_state)
                    rx_idle:
                        if (rx_c_fullhalfbit == 0)
                    rx_start:
                        else
                            rx_c_fullhalfbit <= rx_c_fullhalfbit - 1;
                    rx_rec:
                            begin
                                rx_c_fullbit <= v_fullbit;
                                //rx_data <= {rx_data, rxd_m};
                                rx_data <= rxd_m;
                                rx_c_eight <= rx_c_eight + 4'd1;
                                if    (rx_c_eight == 4'd7)
                                    rx_c_eight <= 0;
                            end
                        else
                            begin
                                rx_c_fullbit <= rx_c_fullbit - 1;
                            end
                    rx_stop:
                          begin
                            data_out_i <= rx_data;
                            end
                        else
                           begin
                             data_out_i <= data_out_i;
                           end
                endcase
            end
    end
    // End Output Logic
    endmodule
    Solution: Didn't specify bus width at the top level and so it was reduced to an implicit net of 1 wire.
