16 years agoAs it seems you're using Windows, the Cygwin layer emulation slows down every thing, compile process in Linux is much faster.
Every Nios II project has a related run-time library, its compilation time is longer than in main project, if you don't change your sopc builder system, run-time library is not recompiled. Are you sure compile messages are showed even if you didn't change the code (gcc calls)?
