9 years agoSize of modules
I am trying to compile a design which can benefit from vectorization. The kernel is performing the same operation on an array of items, but when i use a wider type (int4 instead of int), it fails to ...
9 years agoWith AOC 14, no; with 15 and above you can generate an area report that gives you details of area usage line by line (check Altera's OpenCL documentation). The latest version of the report is provided in v16.1 and above. You should absolutely avoid using old versions of AOC.
