8 years agoSingle work item Task parallel OpenCL kernel
Hi, Does the following code, invokes the kernel to run like the attached image? or they runs one after another ?
clCreateCommandQueue(context, device, NULL, &status);
clEnqueueTask(command...
8 years agoAh, I put the wrong code. Suppose,
clEnqueueTask(command, task1, 0, NULL, &eventtask1); clEnqueueTask(command, task2, 0, NULL, &eventtask2); clEnqueueTask(command, task3, 0, NULL, &eventtask3); Say, Task 1 load 1 Million floats from global memory and channel pass it to task 2. Task 2 then perform summation and channel it to Task 3 Task 3 then write back to Global memory.
