10 years agosine wave using Different duty cycles of PWM
Hi i am having problem in generating different duty cycles of PWM. can somebody check my code and tell what is wrong. well code is generating a duty cycle but it does not change it automatically as t...
10 years agoYes, there must be a "relationship between these" - and the frequency is clearly dependent on which bits you select, as you've seen. I suggest you keep playing around with it - I'm sure you can work out the relationship for yourself.
Cheers, Alex
