Ooo sorry yes I have change it to work and add some calculations so the value 0-4096 represent 0-90 degrees. When I run the simulation I get the max value of 00000000000110.
Here is the code I use for simulation:
-- Quartus II VHDL Template
-- Dual-Port ROM
library ieee;
use ieee.std_logic_1164.all;
use ieee.numeric_std.all;
USE ieee.math_real.all;
entity LUT_ROM is
generic
DATA_WIDTH : natural := 14;
ADDR_WIDTH : natural := 12
port
clk : in std_logic;
addr_a : in natural range 0 to 2**ADDR_WIDTH - 1;
q_a : out std_logic_vector((DATA_WIDTH -1) downto 0)
end entity;
architecture rtl of LUT_ROM is
subtype word_t is std_logic_vector((DATA_WIDTH-1) downto 0);
TYPE ROM IS ARRAY((2**ADDR_WIDTH-1) downto 0) OF word_t;
FUNCTION INIT_ROM RETURN ROM IS
VARIABLE romvar: ROM;
VARIABLE x, i: REAL;
begin
for samp in 0 TO 2**ADDR_WIDTH-1 loop
i := real(0.02197)*real(samp)*MATH_PI/real(180);
x:= SIN(real(i)*MATH_PI/real(ADDR_WIDTH-1));
romvar(samp):= std_logic_vector(to_unsigned(integer(x*real(ADDR_WIDTH-1)),DATA_WIDTH));
end loop;
return romvar;
end;
-- Declare the ROM signal and specify a default value. Quartus II
-- will create a memory initialization file (.mif) based on the
-- default value.
signal rom_val : ROM := INIT_ROM;
begin
process(clk)
begin
if(rising_edge(clk)) then
q_a <= rom_val(addr_a);
end if;
end process;
end rtl;
Thank you for your help :)
