9 years agoSimulation/Testbench files in Quartus-II
Hi All, In Quartus-II, how the tool distinguish between the RTL (design) and Simulation files? How should I add the Simulation/Testbench files to Quartus-II project? How should I mark them...
9 years agoFor RTL simulation files (.v or .vhd), Quartus cannot distinguish between synthesis and simulation files other than when you try to synthesize a simulation file that has commands that can't be synthesized.
All you need to do in Quartus is add the synthesis files in the project settings, setting one of them as the top-level entity. Any files not in the settings, even if it is in your project directory, will not be used for synthesis.
