14 years agoSimulation Question
I'm a student who is learning how to use Quartus II with the 11.1 web edition. Our teacher had an old tutorial guide that used vector waveform editor which I guess has been taken out of this edition and replaced with the TimeQuest Timing Analysis tool. I understand everything up until the part where I have to setup for the simulation of my circuit. It's a simple circuit:
f=x1x2 + x2'x3 I have gone through the new tutorials but they seem to require a clock setup. Using the old example which is supposed to run from 0-160ns I tried setting up the inputs with the TimeQuest Timing Analysis Wizard but I must be doing something wrong because it doesn't seem to print out the results I want. I am looking for some document that basically covered the differences and similarities between setting up the simulation in the waveform editor and the new TimeQuest Timing Analysis. Thanks in advance for any help. gabriela
