SimonRichter
5 years agoSimulation: override warnings during compilation, and Intel rebranding breaking generated scripts
I'm trying to get simulation for IP cores running from the command line.
My first approach was to generate a tcl script using
ip-setup-simulation --output-directory=simulation --quartus-...
Nurina
5 years agoHi Simon,
While your project did show that the workarounds worked, we still don't have proof that the error/warning is showing up, so I cannot report this to our engineering team. Using Quartus Prime Lite 20.1.1, I tried deleting the simulation files from the project then have it go through the normal NativeLink flow, and there were no problems. I also tried this demo design just to make sure and there were no problems either: https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/ug/archives/ug_gs_msa_qii-17-0.pdf?wapkw=quick-start%20quartus%20standard
I think you might have gone through a bad installation, could you try to reinstall both Quartus and ModelSim? Maybe try Quartus version 20.1 instead.
Nurina
