15 years ago --- Quote Start --- Hi all, I am trying to simulate the FFT megacore using modelsim. I compile the project and open modelsim separately. I add my design files to a created work directory, including the .vo file. It is not working and i'm a bit stuck on where to go from here, even after reading the tutorials and documentation. Can anyone give a step by step guide on how to simulate the FFT core after compilation in quartus? Thank you, Gabriella. --- Quote End --- Hi, you would like to run simulation after P&R ? Did you get a functional mishaviour or do have a problem with the flow ( e.g. Modelsim compile error ) ? Kind regards GPK
