16 years agoBy the way, by your recommendation I've precalculated the count outside the process and surprisingly it has reduced the number of hold time and setup time violations. Still, there are some lingering around, what should I do about them?
Here is the new process
DB_T3PWM_proc: process(CLKOUT)
variable counter_en : STD_LOGIC;
variable prev_T3PWM : STD_LOGIC;
variable count : UNSIGNED (8 downto 0);
begin
if(rising_edge(CLKOUT)) then
-- if we see a transition, start the clock and enable deadband
if(prev_T3PWM /= T3PWM) then
counter_en := '1';
count := EVB_count;
end if;
-- if we've reached 0, stop counting and disable deadband
if(count = "000000000") then
counter_en := '0';
-- else decrement counter by one
else
count := count - 1;
end if;
-- remember T3PWM for next time
prev_T3PWM := T3PWM;
-- and output delayed PWM outputs
PWMB7_DB_reg <= T3PWM and not counter_en;
PWMB8_DB_reg <= not T3PWM and not counter_en;
end if; -- if rising_edge(CLKOUT)
if falling_edge(CLKOUT) then
end if;
end process DB_T3PWM_proc;
