simulation error
- 5 years ago
still I am getting the same error even after updating the modelsim tool
Thank you
As I understand it, you have some inquiries related to simulating a design with ATX PLL and Native PHY. For your information, I have attached a simple simulation example previous from wiki for your reference. This design consist of ATX PLL + Native PHY.
To run the simulation, do the following:
1. Unzip and change Modelsim working directory to the folder
2. Type "source simulation_setup.tcl"
3. Type "ld" to compile the required files
4. Type "simulate" to populate the waveforms and run the simulation
This example is intended for dynamic reconfiguration. You may ignore the dynamic reconfiguration steps in test bench and focus on how to setup and simulate with Native PHY.
Chee Pin
please check this SNAP SHOT, this obesrvation captured from example project. same issue i am facing in my project
- CheepinC_altera5 years ago
As I understand it, this simulation example was created for Q15.1. Just to check what is your Quartus version?
Thank you.
Just to follow up with you on this. Thank you.
