15 years ago --- Quote Start --- Have you deleted both packages std_logic_arith and std_logic_signed from your code? unsigned(7 downto 0) := x"00" is perfectly legal code with numeric_std. --- Quote End --- I'm sorry. I made a mistake. I had checked it. I do with QuartusII version 5.0 and Modelsim SE PLUS 5.7d. With QuartusII it is ok. But with Modelsim it still has error. I send this file to you and hope you help me to solve this problem. Thank you very much This is the error it notice me in Modelsim --- Quote Start --- # do Counter_run.do # vsim -sdftyp /i1=Counter_vhd.sdo work.<counter>vhd_vec_tst # ** Error: (vsim-3170) Could not find 'modelsim_work.work.<counter>vhd_vec_tst'. # Error loading design # Error: Error loading design # Pausing macro execution # MACRO ./Counter_run.do PAUSED at line 1 --- Quote End ---
