15 years ago --- Quote Start --- 1. Create your waveform vector file in Quartus II 2. Export this file to vhdl test bench (file->export) 3. Click, asssigments->settings->EDA tool settings->Simulation , choose modelsim altera. chooose compile test bench in native link settings panel, click test benches, click new, chosse any name for test bench, in test bench entity write: <your_top_level_entity>vhd_vec_tst in instance name write : i1 chosee the file generated in step 1 in test bench files. 3. Compile your project. 4. click, tools->eda simulation tools: run eda rtl simulation for functional simulation or run eda gate level simulation for timing simulation. After this steps quartus ii opens modelsim an starts the simulation. --- Quote End --- I do step by step follow your introduction. When I run eda rtl simulation or functional simulation, I met a lot of problem: This is error:
Error: Compilation of design file Counter.vho was NOT successful
Error: ModelSim: Model Technology ModelSim SE vcom 5.7d Compiler 2003.05 May 10 2003
Error: ModelSim: -- Loading package standard
Error: ModelSim: ** Error: (vcom-19) Failed to access library 'cycloneii' at "C:/Modeltech_5.7d/win32/../altera/vhdl/cycloneii".
Error: ModelSim: No such file or directory. (errno = ENOENT)
Error: ModelSim: ** Error: Counter.vho(29): Library cycloneii not found.
Error: ModelSim: -- Loading package std_logic_1164
Error: ModelSim: ** Error: Counter.vho(31): Unknown identifier: cycloneii
Error: ModelSim: ** Error: Counter.vho(33): VHDL Compiler exiting
Error: ModelSim: child process exited abnormally
Error: NativeLink simulation flow was NOT successful
Error: For messages from NativeLink scripts, check the file D:/Quartus_code/Quartus5/Countertest/quartus_nativelink_simulation.log
This is log file:
Info: Start Nativelink Simulation process
Info: Initialization of EDA simulation settings was successful
========= EDA Simulation Settings =====================
Family : CYCLONEII
Quartus root : c:/altera/quartus50/bin/
Quartus sim root : c:/altera/quartus50/bin/../eda/sim_lib
Simulation Tool : modelsim-altera
Simulation Language : vhdl
Version : 87
Sim Output File : Counter.vho
Sim SDF file : Counter_vhd.sdo
Sim dir : simulation\modelsim
Info: Changed to directory simulation\modelsim ...
Info: Current directory is : D:/Quartus_code/Quartus5/Countertest/simulation/modelsim
Info: Running ModelSim-Altera software
Info: VHDL script : c:/altera/quartus50/bin//modelsim_vhdl.tcl
Info: Initialization of NativeLink successful
Info: Initialization of EDA advanced simulation settings was successful
Info: Creating directory modelsim_work for VHDL simulation
Info: Compiling design file Counter.vho
================The following additional information is provided to help identify the cause of error while running nativelink scripts=================
Nativelink TCL script failed with errorCode: CHILDSTATUS 3836 2
Nativelink TCL script failed with errorInfo: Model Technology ModelSim SE vcom 5.7d Compiler 2003.05 May 10 2003
while executing
"exec vcom $cmp_opts -work modelsim_work $src "
This is my code (just a simple counter up)
library ieee;
use ieee.std_logic_1164.all;
use ieee.std_logic_arith.all;
use ieee.std_logic_signed.all;
entity counter is
port (result : out std_logic_vector(7 downto 0);
clk : in bit;
reset : in bit);
end;
architecture only of counter is
signal count : std_logic_vector(7 downto 0);
begin
process(clk,reset,count)
begin
if (reset ='1') then
count <= x"00";
elsif clk'event and clk = '1' then
count <= count + '1';
end if;
result<=count;
end process;
end only;
and EDA setting I attached in this post. Could you help me solve this problem. thank you very much best regards
