appu69
7 years agoSimulating gate delays
Hey! I recently started using Intel Quartus Prime Lite edition for simulating Verilog codes. I came across the topic of gate delays in a book.. for eg. In a verilog code if I write a line of code...
AnandRaj_S_Intel
7 years agoHi,
Look into example from below link.
If you are using modelsim/VWF
Launch gate level simulation from tools/VWF->Run simulation Tools->Gate level/timing simulation. Before that you need to setup path go to tools->options->EDA Tools option->modelsim altera ->give the modelsim path example "C:\intelFPGA\17.0\modelsim_ase\win32aloem".
You can find more useful information from previous threads kindly check below threads.
Anand
