10 years agoSimulating Count Binary with Modelsim?
Hi I am new to all this and just got done with hello world and finally got that to work with VHDL, now I am having problems with the count binary template.
I am trying to do the count binary template and simulate it through modelsim but none of the LEDs are working and I named everything the way the document says to. The only thing that is changing values is the processor write and read data. I believe I have attached my qsys files. I am sure I am missing something. I do not get the Hello From Nios2. Can I force the switches while I run? I am running for 2 ms like the AN351 document. Thanks1 Reply
So the only problem I am stuck on is simulating the switches in modelsim, because I get values counting out on the lcd, seven segment, or led.
