Simulate ADC PLL FPGA MAX10
On this video I try simulate PLL https://youtu.be/Yf15rAGqxQw
My target is to simulate the ADC module. But at the moment simulation of the PLL module does not work. what am I doing wrong ??
- AnandRaj_S_Intel
To perform the ADC simulation in Max® 10 device please check below link.
https://www.youtube.com/watch?v=6UscboZ1Vho
Anand
- mmare6
I watched this movie before. From this video I learned that ADC can be simulated.
This video shows how to add an extended output file to the ADC simulation. But my problem is that the simulation does not generate ADC and PLL output signals.
Probably I have a error somewhere. I am a beginner, and I can not find my mistake.
- AnandRaj_S_Intel
You have to include the test bench in Quartus project you need to change the settings to include your testbench.
Settings->EDA Tools Setting ->simulation -> select compile testbench ->click testbenches->click new and add the file generated ->ok->apply->ok
Add .vht file in quartus and start analysis and elaboration and launch Modelsim.
Refer below link for steps
http://denethor.wlu.ca/pc120/quartus_testbench.shtml
Anand
- mmare6
thank you for the support.
Below I will explain my mistakes
And I show what I corrected that the simulation started correctly.
remove *.sip file from project
1 Option change to Verilog HDL 1 ps
2 Add testbench. TestBench name is important. Must be The same as top level entity
on this video I show step by step how to do it correctly https://youtu.be/YbOnfNFJg6Y
