13 years ago --- Quote Start --- I'm nut even sure how this code can run in a simulator without any errors but you should maybe check your algorithm first. In this line
sum:=sum + x(k)*y(n-k);(n-k) can take a lot of values outside of the range 0 to 1, and that should cause an error in the simulator real quick. You do realize that this code isn't synthesizable on real hardware, don't you? --- Quote End --- thank you for your reply actually i want to simulate an upsampler (in DSP); and for implemet this ,i need to implement a convolution function,therfore i used that vhdl code(that is sent) and that is wrong. i don't know how can do it;please help me thank you hello,i changed my vhdl to the following code,but the output remains 0 and dosen't change when the inputs change,where is my mistake?? package mypack is type real_vec is array(integer range <> ) of real; end mypack; library IEEE; use IEEE.STD_LOGIC_1164.ALL; use work.mypack.all; entity conv1 is generic (m:integer :=3; n:integer :=1); port (x:in real_vec(0 to m); y:in real_vec(0 to n); f:out real_vec(0 to m+n)); end conv1; architecture Behavioral of conv1 is signal h : real_vec(-(m+n) to m+n):=(others =>0.0); --signal h : real_vec(-m to n):=(others =>0.0); signal sum:real:=0.0; begin process (x,y) begin h(0 to n) <=y; for i in 0 to m+n loop for k in 0 to m loop sum <= sum + x(k)* h(i-k); end loop; f(i) <= sum; sum <=0.0; end loop; end process; end Behavioral;
