13 years ago
simplest way to make a pin high or low in verilog
someone kindly suggest a simplest way to make a pin high or low in verilog
the board i am using is DE2 115
thank you
1 Reply
    module fpga_main {
       out0,
       out1,
       // more i/o pins
    output out0;
    output out1;
    assign out0 = 1'b0;  //pin low
    assign out1 = 1'b1;  //pin high
    // other code
    endmodule
    Then use Quartus pin assignment feature to route out0 and out1 signals to proper fpga pins
