16 years agoHello,
Altera has DDR controler IP available. For your purposes, I believe the easiest way would to make your processed data available with an Avalon interface. Can be either an Avalon-MM slave or a or Avalon-ST source. At your rates, it hardly matters. You can then build a SOPC with a) your component b) a DDR controler component c) a NIOS II processor component d) JTAG-UART component to handle the data transfer "b)" to "c)" are readily available for you in the SOPC builder. You can then write a small program (in C) for NIOS to read processed data from your component and store it in DRAM and to comunicate with the PC over USB-Blaster.
