18 years agoThe Quartus project referenced in my previous post is attached in cascaded_ands.zip.
The code that goes with my previous post:library ieee;
use ieee.std_logic_1164.all;
entity cascaded_ands is
port
in_a1 : in std_logic;
in_a2 : in std_logic;
in_a3 : in std_logic;
in_a4 : in std_logic;
in_a5 : in std_logic;
in_a6 : in std_logic;
in_b1 : in std_logic;
in_b2 : in std_logic;
in_b3 : in std_logic;
in_b4 : in std_logic;
in_b5 : in std_logic;
in_b6 : in std_logic;
out_1and_withkeep_pin: out std_logic;
out_2ands_withkeep_pin: out std_logic;
out_3ands_withkeep_pin: out std_logic;
out_4ands_withkeep_pin: out std_logic;
out_5ands_withkeep_pin: out std_logic;
out_1and_withoutkeep_pin: out std_logic;
out_2ands_withoutkeep_pin: out std_logic;
out_3ands_withoutkeep_pin: out std_logic;
out_4ands_withoutkeep_pin: out std_logic;
out_5ands_withoutkeep_pin: out std_logic
end entity;
architecture rtl of cascaded_ands is
signal out_1and_withkeep: std_logic;
signal out_2ands_withkeep: std_logic;
signal out_3ands_withkeep: std_logic;
signal out_4ands_withkeep: std_logic;
signal out_5ands_withkeep: std_logic;
signal out_1and_withoutkeep: std_logic;
signal out_2ands_withoutkeep: std_logic;
signal out_3ands_withoutkeep: std_logic;
signal out_4ands_withoutkeep: std_logic;
signal out_5ands_withoutkeep: std_logic;
attribute keep: boolean;
attribute keep of out_1and_withkeep: signal is true;
attribute keep of out_2ands_withkeep: signal is true;
attribute keep of out_3ands_withkeep: signal is true;
attribute keep of out_4ands_withkeep: signal is true;
attribute keep of out_5ands_withkeep: signal is true;
begin
out_1and_withkeep <= in_a1 and in_a2;
out_2ands_withkeep <= in_a3 and out_1and_withkeep;
out_3ands_withkeep <= in_a4 and out_2ands_withkeep;
out_4ands_withkeep <= in_a5 and out_3ands_withkeep;
out_5ands_withkeep <= in_a6 and out_4ands_withkeep;
out_1and_withoutkeep <= in_b1 and in_b2;
out_2ands_withoutkeep <= in_b3 and out_1and_withoutkeep;
out_3ands_withoutkeep <= in_b4 and out_2ands_withoutkeep;
out_4ands_withoutkeep <= in_b5 and out_3ands_withoutkeep;
out_5ands_withoutkeep <= in_b6 and out_4ands_withoutkeep;
out_1and_withkeep_pin <= out_1and_withkeep;
out_2ands_withkeep_pin <= out_2ands_withkeep;
out_3ands_withkeep_pin <= out_3ands_withkeep;
out_4ands_withkeep_pin <= out_4ands_withkeep;
out_5ands_withkeep_pin <= out_5ands_withkeep;
out_1and_withoutkeep_pin <= out_1and_withoutkeep;
out_2ands_withoutkeep_pin <= out_2ands_withoutkeep;
out_3ands_withoutkeep_pin <= out_3ands_withoutkeep;
out_4ands_withoutkeep_pin <= out_4ands_withoutkeep;
out_5ands_withoutkeep_pin <= out_5ands_withoutkeep;
end rtl;
