Altera_ForumHonored Contributor18 years ago"Simple" delay chain mystery I have cascaded 5 AND2 gates, and in a timing simulation compare the outputs of all of the gates against each other. Each AND2 gate has its uncascaded input connected to a PIN, and each output is br...Show More
Recent DiscussionsFailed to run ip-setup-simulation:Compile option not saved (reversed to default)How to fix Error(23782): Failed to find an expected reportSSLC Login Issue – "You need to enroll" loop after OTP verificationFree Licence for Max+PlusII
