18 years agoI expect the compiler to start generally with a parallel solution for each logic term. It may reuse existing terms, if this gives a LUT usage benefit and doesn't conflict with timing constraints or general optimization rules. Also different routing effort may be a reason to prefer a parallel solution in some cases.
