16 years ago --- Quote Start --- Thx for response, but do not understand 're-run the project with the new version and all should be fine.' When I compile 9.1 w/o SigTap all is ok. But when I enable the SigTap, and reference the previous STP file I get failure: Error: Can't compile project with SignalTap II instance "sld_signaltap:auto_signaltap_0" in unsupported SignalTap II version 5. Current SignalTap is version 6. So what do I need to do? Do I need to re-enter the SignalTap data from scratch? I seem to remember that a 'Talk Back' had to be enabled for the free version but don't remember where the option was or if still required. Is this the problem? --- Quote End --- Hi, re-open your signaltap file in the new version. There should pop-up a warning that the file is generated by an older version of Quartus. Save the file and all should be ok. Sorry for forgetting that you have to open the signaltap file. Kind regards GPK
