12 years agoSignalTap working on Windows but not on Linux
Hi!
I'm having some problems when trying to use SignalTap on Linux. I'm using two different setups: - DE2 development board with integrated USB Blaster - Custom board (EP4CE15) + external USB blaster clone The thing is, on Windows I can use SignalTap on both setups with no problem. On Linux I can use SignalTap with the DE2 but not on my custom board. Programmer works OK though. As far as I know it's only SignalTap what it's not working. Do you know what could the problem be? Anything I can try? Thank you very much for your help! Information that can be useful: - Linux Quartus II 64-Bit Version 13.0 Build 156. I tested also 12.1sp1 with same behaviour. - Tested on Ubuntu 12.04 and 13.04 64 bits "lsusb -v" for DE2 and USB blaster clone differ slightly on bMaxPacketSize0 and some names and serial numbers. I don't know if that could be a problem DE2 USB Blaster
$ sudo lsusb -v -d 09fb:6001
Bus 005 Device 003: ID 09fb:6001 Altera Blaster
Device Descriptor:
bLength 18
bDescriptorType 1
bcdUSB 1.10
bDeviceClass 0 (Defined at Interface level)
bDeviceSubClass 0
bDeviceProtocol 0
bMaxPacketSize0 8
idVendor 0x09fb Altera
idProduct 0x6001 Blaster
bcdDevice 4.00
iManufacturer 1 Altera
iProduct 2 USB-Blaster
iSerial 3 91d28408
bNumConfigurations 1
Configuration Descriptor:
bLength 9
bDescriptorType 2
wTotalLength 32
bNumInterfaces 1
bConfigurationValue 1
iConfiguration 0
bmAttributes 0x80
(Bus Powered)
MaxPower 150mA
Interface Descriptor:
bLength 9
bDescriptorType 4
bInterfaceNumber 0
bAlternateSetting 0
bNumEndpoints 2
bInterfaceClass 255 Vendor Specific Class
bInterfaceSubClass 255 Vendor Specific Subclass
bInterfaceProtocol 255 Vendor Specific Protocol
iInterface 2 USB-Blaster
Endpoint Descriptor:
bLength 7
bDescriptorType 5
bEndpointAddress 0x81 EP 1 IN
bmAttributes 2
Transfer Type Bulk
Synch Type None
Usage Type Data
wMaxPacketSize 0x0040 1x 64 bytes
bInterval 0
bLength 7
bDescriptorType 5
bEndpointAddress 0x02 EP 2 OUT
bmAttributes 2
Transfer Type Bulk
Synch Type None
Usage Type Data
bInterval 0
Device Status: 0x0000
(Bus Powered)
USB Blaster clone
Bus 005 Device 002: ID 09fb:6001 Altera Blaster
Device Descriptor:
bLength 18
bDescriptorType 1
bcdUSB 1.10
bDeviceSubClass 0
bDeviceProtocol 0
bMaxPacketSize0 64
bcdDevice 4.00
iProduct 2 USB-Blaster-ARM????
iSerial 3 8D8C41695350
bLength 9
bDescriptorType 2
wTotalLength 32
bNumInterfaces 1
iConfiguration 0
bmAttributes 0x80
(Bus Powered)
MaxPower 150mA
bLength 9
bDescriptorType 4
bInterfaceNumber 0
bAlternateSetting 0
bNumEndpoints 2
iInterface 2 USB-Blaster-ARM????
bLength 7
bDescriptorType 5
bmAttributes 2
Transfer Type Bulk
Synch Type None
Usage Type Data
bInterval 0
bLength 7
bDescriptorType 5
bmAttributes 2
Transfer Type Bulk
Synch Type None
Usage Type Data
bInterval 0
(Bus Powered) For both USB blasters, this is the udev configuration. $ cat /etc/udev/rules.d/51-usbblaster.rules# Altera USB-Blaster for Quartus FPGA Software
SUBSYSTEMS=="usb", ATTR{idVendor}=="09fb", ATTR{idProduct}=="6001", MODE="0666"
SUBSYSTEMS=="usb", ATTR{idVendor}=="09fb", ATTR{idProduct}=="6002", MODE="0666"
SUBSYSTEMS=="usb", ATTR{idVendor}=="09fb", ATTR{idProduct}=="6003", MODE="0666"# USB-Blaster II
SUBSYSTEMS=="usb", ATTR{idVendor}=="09fb", ATTR{idProduct}=="6010", MODE="0666"
SUBSYSTEMS=="usb", ATTR{idVendor}=="09fb", ATTR{idProduct}=="6810", MODE="0666"
If you need any additional info, please let me know.
