11 years agoSignaltap State-Based Triggering Flow
Hello, i've read this page: http://www.altera.com/support/examples/on-chip-debugging/signal-tap/signaltap2-design-examples.html and the Handbook. But I've still two questions. When is...
11 years agoI find it just easier to add detection logic in your RTL. Then you know for sure when odd conditions over several clock cycles have occured.
You can use the syn_keep attributes on registers so you can then connect them to signaltap.
