11 years agoSignalTap Program device to continue
1st post, treat me gentle. I searched the forum and did not find an answer to my problem. I have an infrequent failure that locks up my design. Yesterday the test guy was running and had the failu...
11 years agoMore info
(Hey carriage returns are working now, I wonder what I did wrong yesterday) I did the build in a batch run on Linux. I then opened the project on a PC with a bridge to the Linux file server. I then opened Signaltap and experienced the problems above. Any ideas? CarlBoydSBasa5
6 years agoHello Carl.
I have encountered similar obstacle. I want to signaltap after FPGA is reconfigured from flash (with the SAME binary image - i have triple checked this).
But signaltap complains:
Invalid JTAG Configuration / Error (261005): Can't find the instance. Download a design with SRAM Object File containing this instance.
Does signaltap require single JTAG session for programming and debugging?
I know it has been long time but if you found solution please share :)
