17 years agoSignalTap Node Netlist Type
Hi, I'm using Quartus 7.2sp3.
I have a huge SignalTap Nodes list added with the "SignalTap II: post-fitting" Filter. Now I wanted to add the Nios II Nodes through the Nios II plugin. However, during synthesis, Quartus now outputs critical warnings like the following one: Critical Warning: Can't connect signal "avalon_system:avalon|cpu:the_cpu|A_iw[0]" to SignalTap II instance "sld_signaltap:auto_signaltap_0" because the signal does not exist Also the values of these Nios II Nodes displayed by SignalTap are always <empty>. As suggested in the Quartus Help, I've tried to switch the partition Netlist Type to "Source file" but nothing changed. Also the question comes up how I can have a mix of node types in my SignalTap? Because I have set the Netlist type to "Post fit" in my design partitions window because of the following warning: Critical Warning: SignalTap II instance "sld_signaltap:auto_signaltap_0" taps the post-fitting node "EBvBusGen:ebvgen|pixCnt[26]" in a partition with a Netlist Type that is not Post-Fit or Post-Fit (Strict) In earlier Quartus versions, I think to remember an option (a checkbox) for each node where I could set it's netlist type (pre-synthesis or post-fit) but this option isn't there in the 7.2 version. I would love to have my nodes there and the (rather complex) advanced triggers I've created so far and the Nios II Nodes included. Any suggestions? Thanks!
