12 years agoSignalTap II won't recognize recompile
Hi All, I have an instance of signaltap I've been working with in my design for the last couple weeks. Last Friday I recompiled the project after a design change and now signaltap won't recogn...
9 years agoInstead of recreating the SignalTap file, which can be quite an amount of work try the following:
Close SignalTap Open the .stp file in an editor Look for the line "<instance enabled="true" entity_name=...." If the entity_name is anything else than "sld_signaltap", e.g. it is prefixed by something, this can be the problem. Replace it by entity_name="sld_signaltap". Save the stp file and recompile the project. Now you should see in the Quartus Hierarchy view the instance "sld_signaltap:<instance_name>" and everything should work
