17 years ago --- Quote Start --- How do you change the locked options in QII? I did not see the ability to change this mode when I built the component in Mega-wizard. --- Quote End --- I didn't realize you were using the Mega-Wizard. I never used the Mega Wizard for Singal Tap, but that is probably the reason that locked mode can't be changed. You normally don't use the Mega-Wizard with Signal Tap. Create a new STP file directly with Quartus (New File on the Quartus menu). Then you'll get the Singal Tap Windows GUI with all the options enabled.
