17 years agoExcellent, thank you.
How do you change the locked options in QII? I did not see the ability to change this mode when I built the component in Mega-wizard. In the signal tap II window under the menu option Edit -> Lock Mode I do see that I have the option "Allow Trigger Condition Changes only" selected but that, too, is grayed out so that I cannot change it if I wanted to. Thank you, Br
