13 years agoQuartus 9.1 was the earliest version that supported the Cyclone IV line of parts.
The web-edition signaltap should work just fine in Quartus 10.0 with talkback turned on. So long as you ran tb2_install.exe and checked the option, it should be enabled. I am running Q10.1 with talkback and have had little issues with signaltap for use with Cyclone IV. Try re-running tb2_install.exe again. If this does not work, I'm out of ideas. Good luck.
