8 years agoSignalTap II - waiting for clock
Hi, I'm attempting to use SignalTap II to verify my design is running correctly. I have set the SignalTap signals to be from pre-synthesis to prevent my desired signals from being optimised out...
8 years agoWhat does it mean "found it in assignment editor" ? Did you do the pin assignment of the mentioned clock?
You should look into your board reference manual to get the pins reserved for reference clocks.
